New built motor for sale. Here's the build list,
Block was magnafluxed, partial fill, bored 20 over, line honed and decked.
Crank was polished and balanced, Crower rods balanced, girdle with ARP main studs, oil squirters are welded, oil pickup tube is welded and modified.
Gearhead stage I cam with the gear tig welded,
Pistons and bearings are coated, pistons are balanced and machined for proper protrusion and the bowls cut back.
Heads have H11 studs, fire rings, DI push rods, behive springs.
Hardend valve seats with 3 angle grind, ports have been cleaned up and the valve seat unshrouded.
ATS billet fly wheel, new melling oil pump and new water pump,
Asking $8,000 OBO
PM me if you have questions. I can only get on here after work but will check back in everyday.
Thanks for looking.
Asking $8,000 OBO
Thanks for looking.
