My 4294r spools just like the 38r did and I do have plans for bigger injectors when the built motor goes in.
Every turbo and injector combo I've run in the past would pull below 1800 RPM's a bit but right at 1800 and above, it was game on, dial a boost with the throttle.
I dont want to run a compound combo that moves that 1800 RPM point up any higher.
I would really like to get that dial a boost point to come down a bit with a compound setup if I could.
Can you pm me all the specs, compressor inducer and exducer sizing and same for the tubine side?
I only want to build the plumbing setup one time.
Thanks
