Lamont_24
I did the Dana 60 swap with new a tie rod, drag link, and track bar and now I've got a really bad bump steer and the steering doesn't respond back. It doesn't want to return to neutral is the best way to describe it. The track bar is at a good angle, pretty much parallel with the drag link. I've ruled it down to the steering shaft or maybe the gear box. I've been thinking about slapping a steering stabilizer on it and seeing if that makes a difference. But I wanted to see what kind of input you guys have. Thanks
