psdguy95
My truck currently doesn't have them and I have a recon set on the way to put on it. Where do these things hook up to? Is there a plug under the dash or am I going to have to splice them in?
the factory harness will need splicing for the recon unit
the recon harness was ok it was the mismatched plugs that I had an issue with
they also didn't include the inserts for the screws but the screws sucked anyways
not sure if they updated their kits http://www.powerstroke.org/forum/99...cussion/112464-mounting-recon-cab-lights.html
if I ever do it again ( might have to since they all have moisture inside ) I am going OEM with smoked lenses and Led replacement bulbs
Atomic's about 300 bucks look cool and have good feedback http://youtu.be/8_728D_wuLE
I am not sure how long the recons electrical board will hold up with moisture so I might be able to try those soon
