isootmypants
Searched the forums, couldnt really find a direct answer. I have the 4 hole plate, 350 rear springs with overload, 250 Gasser springs in the front, Rancho shocks, the cheap FX4 ones. 20" with Nitto 420s.
When I launch at the track, the truck jumps up and does not squat, kinda like axle wrap, and hops the first 25-30 ft when I side step the brake pedal. When I slowly let off on a launch to where it doesnt have the intial jolt, it squats, no hop.
I had them set on the bottom hole, 1-1/2 turns tightened after the bolt hits the spring.
I tried the hole above that (3rd front top), **** hair between the bolt and spring, hopped even harder.
Tire pressure is 43lbs.
Launching between 12-18lbs.
ECSB.
Any help??
ECSB.
Any help??
