CCV Kit Question
AirMedic84
I'm just about to take the plunge and do a full delete on my 2014 6.7. I'm just curious if the CCV Kit would be a good addition to the list sooner than later. Also since I haven't seen a whole lot of info on the CCV Kit for the 6.7 I'm just curious if the vacuum from the intake actually helps with the ventilation and if taking that away will have any adverse effects. Any information would be greatly appreciated. Thanks.
No adverse effects. There really isn't enough vacuum in the intake to positively effect the crankcase anyway. If you want to keep the oil out of your intake, it's a great way to go.
LovinPSDs
Evansville, Indiana
The turbo doesn't create a big enough vacuum? I'm not pokin fun here, I actually want to know because people seem to kick this back and forth a bunch.
CWAY6.7
I've seen the inside of my intake, and it is not pretty. I wish I would have done this mod sooner than 90k
I'm saying there isn't enough vacuum in the intake to create a noticeable performance gain like you would see running a vacuum pump or dry sump system in a race car. Yes, there is a small amount but not enough to make a difference or be worried about just venting it to the atmosphere.
