pedaltheglobe
- Joined
- May 11, 2014
- Messages
- 78
- Reaction score
- 0
One of the previous owners of my truck used two 4 inch stacked blocks in the rear to lift the truck. Seems totally unsafe.
I'm replacing them with 5 inch blocks from Rough Country. They used lift coil springs and 3-4 inch lift coil spring insulators to lift the front.
To level out the truck I'm replacing the aftermarket coil spring insulators with a factory spec size. Does anyone know where I can source these? I have heard them called both insulators and isolators, but when I google them not a lot comes up. The only thing I found are "coil lift isolators" from Energy Suspension. I can't figure out if I can use these as a replacement or if they are to be used in conjunction with the factory isolators?
http://www.energysuspensionparts.com/proddetail.asp?prod=4.6111
I would like to do the job this evening if anyone knows how I could source this part locally...
Your help is appreciated.
