Cold Air Vs. Stock Air
schmity
I was fumbling around on the internet trying to convince myself that I needed a CAI for my 6.4. I eventually came across the test results comparing the S&B CAI and the stock 6.4 Air filter (http://www.pureautoparts.com/docs/ISO-5011-Test-Results-for-75-5018.pdf). Sure enough the S&B flows 23-24% better, but that is with a clean filter. What really got me questioning things is when you look at the capacity of the filters the stock filter will handle almost 1400 g of particulate/dust/whatever while the S&B will hold 160-230 g depending on which filter you get. That about a 7 fold advantage to the stock filter over the S&B.
My question is:
1) No doubt the S&B has better airflow when it is clean, but how long does it take before it has the same restriction? I'm thinking not that long….
Anyone else wrestled with this? Is there a larger donaldson powercore tech filter that would fit as a drop-in? Is there really any need for a larger filter for milder chip settings (a tow rig?)
HeavyAssault
Middle, VA
Someone who actually can read between the hype!! Thanks for posting this. I've been trying to show this for years.
Unless you really "need" the CAI a stock unit will do the job. No Limit uses S&B filters if I recall correctly and the resulting increases have been proven.
bft blue oval boys
Burlington, NC
If you're not worried about power or putting it on a higher power setting and want the most protection then staying stock is probably your best bet. If you do ever upgrade though, No Limit is definitely the way to go.
swinky
Eastern, Nc
Smart man. That mod should work great on my truck and it'll probably be free...
That's why 6.4s don't blow head gaskets
Lol I type blow and " head gaskets" are the next two words in my predictive text. A couple years ago blow would've been something totally different :p
