comp 910 spring install with shims
ju015dd
Tallahassee, FL
Just wanted to make sure I have this going the correct way for me. I measured 1.805 for the first valve spring. 1.805- .045 for the factory seal and then - .015 to equal 1.745. Is this correct or do I have it all fubarred
TARM
Yes you have it correct. Do the same for each valve and use the correct.size shim or combo of shims to get you as close to the same final spring hieght for each which in this case you are using 1.745"
ju015dd
Tallahassee, FL
Thanks Tarm! I was hoping I was understanding your literature correctly. Glad to see you back posting and helping guys like me with all your knowledge and wisdom!!:toast:
