Complete Build Thread
g2shuck
OK guys so I decided I am gonna go ahead and start taking the truck apart and do the head gasket work myself instead of paying a shop... so I am starting a build thread. Please check my parts list below and tell me if I am missing anything as this is my first build on a 6.0. I already have Edge CTS, AFE intake, and MBRP 4 inch turbo back exhaust. I decided that I might as well do everything on the how to make a 6.0 bulletproof sticky while it was all apart. The only things off that list I didn't decide to do was the remote oil cooler kit and the oil bypass filter setup.
I have 36 gallons of distilled water, a gallon of restore, a gallon of restore plus, and 4 gallons of CAT ELC for the coolant flush process.
injector o rings - 3c3z-9229-AA
oil cooler - 3C3Z6A642CA
6 new copper crush washer for fuel lines - 3c3z-9A375-AA
Ford intake manifold gasket set - 3C3Z-9439-AA
Ford head gasket kit - 4C3Z-6051-EB
Ford exhaust gasket set - 6C3Z-9448-A
Ford valve cover gaskets
Ford Turbo Bolt/O-ring and gasket Kit
Ford Blue Spring fuel pressure regulator kit
6.4 Banjo Bolts
Updated Dummy Plugs - W302908
Updated Stand Pipes - 6E7Z9A332A
STC HPOP fitting update kit - 4C3Z9B246F
Updated oil drain tube - 6C3Z9T515A
Updated oil feed line - 3C3Z9T516A
XDP 6.0L Coolant Filtration System
ARP Studs - 250-4202
EGR Complete Delete Kit
EGT, FP, and Volt gauges in triple pillar pod
6.0 Fuel Pressure Adapter from strictly
SCT X3 with tunes from Vivian
Heads cleaned, pressure checked, and resurfaced
AC system Drained before tear down
The total for all the parts including shipping is $2662.22 not including the coolant flush supplies I already had.
g2shuck
I just attached screen shots of the list I made that included individual prices and where each item was coming from
g2shuck
Just found out you will need this too
Rocker box gasket set - 3c3z6584AA
g2shuck
ill be taking lots of pics.... its gonna be a challenge after today... i wrecked my motorcycle and broke my left wrist but i'm still gonna do truck this weekend
g2shuck
its going goos the ehads are at the machine shop if you look up g2shuck on photobucket i have lots of pics up
