kevin
I'm in the process of putting compounds on my truck.. I would like to see some pics of how the oil drain for the big turbo is routed back into the motor.. thanks
I welded an a/n fitting to the valve cover.. Works like a charm and no pulling the motor to get the pan off. It was a number 4, ive got plenty on stock if you need one.
It was an 8 u beat my ninja edit lol. But still even a 6 would be plenty. The feed line is 1/4" Out the factory fitting on the oil cooler which is a #4 normally
