compound trubos
superstroker99
edenton, N.C.
How does a HX-55 compare to say something like a S366. Looking to do a compound set-up on my 7.3, running 350/200 injectors and ported heads. I already have a S475 88/96 exhaust wheel with the 1.32 housing this will be my LP. Looking for a HP charger is the HX-55 gonna work out? Looking to make good power and still streetable. Dont mind using wastegate if i need to.
Hotrodtractor
Mingo, Ohio
S366:
Best I could find for an HX55:
attachment.php
And that doesn't take into account the turbine differences - I don't have those numbers off the top of my head - but the HX55 won't spool anywhere near as nice as that S366.
silverpsd_06
Wellsville KS
65-66mm inducer on the high pressure turbo and 88or bigger on the atmosphere housings need to be relatively tight on the hp turbo and mid range to loose on the atmo gate both.. preferably a 60mil gate on the high pressure to vent excess exhaust gasses around the turbine you may get away with a 44 on the atmo. dump from high pressure to intermediate pipe to spool the atmo.
Now any smaller than 88 mil your wasting your time don't let anyone tell you smaller is better their stupid if they do. Feel free to ask any other questions people with plenty of knowledge running around here
