Converter lock/unlock
Csilva187
Just wondering if anything has come about with this issue. I remember it being talked about lightly. Anyhow 4th (mini max) converter locks then unlocks winds up then shifts 5th (mini max) locks back up. This all taking place at a kinda getting ****y throttle position through the gears. Thanks fellers!
Dzchey21
wyoming
No I havent had any luck yet. I thought I had something but it turned out to not be anything so I dont know
Sent from my SCH-I545 using Tapatalk 2
Csilva187
Does this also take place with a built transmission and decent converter also? Matt mentioned it was something to do with factory software? Kind of a weird deal I guess why I keep wondering.
Dzchey21
wyoming
Yeah it is actually comanding the unlock not from slip what I can tell
Dzchey21
wyoming
Im going to continue to look into possibilities. I know its hurting me .1 - .2 at the track. Im just kinda against the lock up switch if I can help it
Csilva187
I agree. So tell me this I don't notice this when I'm hammered to the floor from a stop?
Dzchey21
wyoming
Thats the only time I notice it...
What tune are you running?
TD-5
British Columbia Canada
I too have tried but haven't had any luck using MCC to resolve this annoying issue with the 4th tc unlocking & the truck coasting. It looks to me like this is deeper in the transmission programming than we can access with MCC. As long as the transmission sees a minimum of 1% throttle position the converter will stay locked until it reaches the minimum unlock speed as set in MCC. But at any speed when the throttle is brought to 0 the converter unlocks & the RPM drops to idle as if the truck is coasting. then when the throttle is applied again, the converter brings everything back up to speed & the converter clutch locks back up.
When in tow/haul mode the 4th tc clutch does not act like this. It stays locked even with 0 throttle,as long as the vehicle speed is above the MCC unlock setting for the given load. just like 5th in all modes. This suggests there is something in the factory programming that is telling the converter to stay locked in Tow/haul mode but is not in the regular TCM programming??.
Csilva187
I'm running Gearhead tunes via MCC. Everything works great just you get aggressive and lock, unlock, and shift lock. Every time.
