Converter stall?
02POWERSTROKE7.3
Alexandria, IN
Getting ready to start ordering parts to build my 5r110. Need some help deciding what stall converter to get. Running a set of 190/75s and a s366. May jump the injectors up to a 205.
Sent from my SCH-I605 using Tapatalk 2
slc dzl
Riverton, Utah
Agreed. It will spool fine. I run a 2000 stall with my s475 with no issues. I've had higher stalls and I like the lower stall much better.
How well does that s475 build boost "brake boosting" it with the 2000 stall, and how much can you build?
strokin6L
Springville NY
stock stall is around 1600-1800....so yeah 2800 is waaay overkill. I'm looking to do a converter upgrade in the spring. Looking to get a Precision Industries one....maybe the one from RCD.
slc dzl
Riverton, Utah
Im running a 2400 on a stock vgt and stock tuning and honestly Its not bad, but my other setup will be going on shortly.
java
Texas
I'm running a RCD converter with a 2000 stall with my ssx and like it better than stock.
strokin6L
Springville NY
Awesome news thanks for the reply. Been wanting to know/hear from someone with one on a 6L that's running a modded vgt. Does the truck pull harder and accelerate faster with the RCD converter over the stock one?
Josh@DirtyDiesels
PA
No issue building 15-20psi to launch it. Or in 2wd it will start spinning before it gets too high up there... When spooling it though on the brakes you just have to be a little lighter on the throttle and let it come up a little slower. Too much throttle and it just smokes and gets under the charger. I can take a video when I get the truck back together next week or the following.
02POWERSTROKE7.3
Alexandria, IN
Hey Josh would you mind giving me a call? I can pm my number.
