Coolant leaking
Strokin69
timberlake nc
Hey my trk has been bulletproofed and sometimes when I run it on hot mode and really run it I can see some antifreeze came out of the bottle. Has ones trk stil does it after u put studs In it
powerstrokin15
Charleston, WV
what gaskets did you use, also did you check/machine the
heads when you did studs??
also by bulletproofing you mean studs, egr delete, etc. right?
Sent looking at my blown up 6.4
Strokin69
timberlake nc
Yea studs egr off Oem gaskets and machined the heads
I've also talk to some ppl said when I got the upgraded the degas bottle they said the full line is now where the cold fill line is now so I might of had to much in it prolly need to replace the degas cap
powerstrokin15
Charleston, WV
well then yes. like mink said. overfull
i always keep mine at cold line.
glad it wasnt blown gaskets again!
