zilla68
ok, tonite on the way from a couple lawn accounts it sure seemed like my truck was shifting weird, kind of like at 60mph it would shift from 1500 up to 2000 and back. Its run fine for the past 3 years I've had it, I only drive it after work for my lawn accounts pulling a 14ft trailer with a zero turn, couple of push mowers, etc, so its not like its really heavy.
So I get home, throw the mt2500 scanner on it, to see if anything pops up, and while doing the koer test, it just dies, says test aborted, so I just fire it right back up (thank god), and proceed. I was able to pull a bit of info off the transmission side, then I went to the engine side, started to pull in some info, and then it said it had no communication, and did that 3 more times I tried to pull it again, so I gave up. Shut off truck, fired it back up about 3 more times and called it a night.
I pulled:
continuous memory code
po470 exhaust pres snsr ck fault
and
engine running codes-fix second
p0476 exh pres ctrl valve perform
under the transmission side I pulled this information:
ap(v) .53
engoiltemp (v) 1.83
engoiltemp (f) 151
elecprsctrl (psi) 5
epc (v) 8.19
sdcs (or sccs)--
tranfluidtmp (v) 0.84
sccs (v) 6.70
tcc (%) 0
transrange (v) 4.51
torque (lbft) 32
aclpedl (v) 0.53
brakeonoff-off
vehspdsnsr (mph) 0
4x4 low - off
cpp/tcs- on
parkbrakeapply-off
coastclutchsol-on
torqconvcl-off
ivsidle-off
trnctrlindlamp-off
shiftsol1-on
shiftsol2-off
gear-1st
cruise-off
transrange - park
idle was 700rpm
driveability test showed
ap(v)- 0.53
baro (v)- 4.54
arpmdes - 0
baro kpa-98
baro hz- 121
exhbackprs (psi)20
epb(v) 1.57
engoiltemp (v) 1.86
epc (v)8.14
then I lost communication and couldn't get any more info.
alright you guru's does this tell me anything at all?
thanks ahead of time for any input.
I pulled:
and
ap(v) .53
engoiltemp (v) 1.83
engoiltemp (f) 151
elecprsctrl (psi) 5
epc (v) 8.19
sdcs (or sccs)--
sccs (v) 6.70
tcc (%) 0
transrange (v) 4.51
torque (lbft) 32
aclpedl (v) 0.53
brakeonoff-off
vehspdsnsr (mph) 0
4x4 low - off
cpp/tcs- on
parkbrakeapply-off
coastclutchsol-on
torqconvcl-off
ivsidle-off
trnctrlindlamp-off
shiftsol1-on
shiftsol2-off
gear-1st
cruise-off
transrange - park
idle was 700rpm
ap(v)- 0.53
baro (v)- 4.54
arpmdes - 0
baro kpa-98
baro hz- 121
exhbackprs (psi)20
epb(v) 1.57
engoiltemp (v) 1.86
epc (v)8.14
