97strokerHD
- Joined
- Jun 6, 2014
- Messages
- 190
- Reaction score
- 0
When driving my truck at any speed every once in a while it cuts out very quickly. The first time this happened I replaced the cps with one from a local parts store. Fixed the problem for a little while and then it would start again. I have replaced the cps multiple times and finally got a Motorcraft sensor. About the same time I also did an update on the pcm, changed the icp sensor, and cleared all codes. The code that keeps coming back is for cam position sensor signal intermittent. I have thrown enough sensors at it to be pretty sure that's not the problem. Going to check the wiring but need to know if there is any specific areas in the wiring I need to check for chafing or broken wires. Really need to get this fixed.
