cracked piston options/opinions
Oh-ate6.4PSD
Vicksburg,MS
I just bought a truck for a good price with a cracked piston. Lookin at my options for fixing. I bid on a toalted truck with 95k for a motor swap, but if that dosnt come through what would you do? Replace the 1, Set of hd coated pistons, or shortblock? Anything else i havnt thought of yet?
webb06
Seneca, MO
Are you planning on keeping the truck or flipping it? Also depends on if any other pistons are melted and if the cylinder walls are ojay
Stroked777
Casper, Wyoming
If the cylinders are ok I would do hd coated pistons. If the walls are damaged, see if it can be bored out and then get oversize coated pistons to fit the new bored. If it's FUBAR the get a short block and get hd coated pistons
Cknox121
Augusta GA
Like stated of cylinders are okay, throw a set of Pistons in it.
Sent from my cracked iPhone using Tapatalk
Oh-ate6.4PSD
Vicksburg,MS
Thanks for the input guys. Has anyone had a cracked hd piston? I can use stock rods with hd pistons right? Whats the limit of stock rods/stock crank/hd pistons
bigrpowr
<How I Fly
Administrator
I haven't heard of anyone cracking one yet. I stock coated and normal hd Pistons , let me know if I can hook ya up.
Oh-ate6.4PSD
Vicksburg,MS
Ok will do. Guy i bought it from says he had it checked and #7 is cracked. Said he heard the pop and fizz then pulled over and towed it. I got a good runnin xlt rite now ima sell the xlt and keep the fx4
Oh-ate6.4PSD
Vicksburg,MS
Anybody heard of forged pistons tha last 100k or longer?
Bigpowr shoot me a price on a set kinda leanin twoard coated hd cuz im hopeing never to do pistons again. Any input on rod/main bearings? How bout a full gasket kit
wiseguy
northern IN
Hd pistons will work for any stock fuel/turbo truck best bang for buck VR gasket set is about 550 does not come with hpfp cover gasket/harness 120 ish plan for full rebuild on heads new valves & guides ect.. about 900 also plan on new rockers, lifters and push rods 6.4 eat valve train like candy I normally get rods and mains from ford under 160 bucks also budget new timing cover and water pump and thermostats another 750 bucks
wiseguy
northern IN
don't waist your time on used 6.4 they are all junk every 6.4 I have ever torn apart needs rebuilt better to just rebuild what you have "IF" the block is good. If you build it you can fix a lot of internationals mistakes
Athens, IL
You'll be fine with a machined and coated piston. We have hard anodized forged. But I only have a small number of them running and even less in street trucks. And none with anywhere near 100k.
We've got several 1000+ hp trucks with our machined and coated pistons.
http://www.midwestdieselauto.com/64-engine.html
Oh-ate6.4PSD
Vicksburg,MS
Wiseguy that was parts only prices rite?
Im makin a list rite now. How bout a cam and ported heads? If im building mite as well BUILD it, not extreme butwhile im in the bottom end.....
bigrpowr
<How I Fly
Administrator
Bigpowr your pistons delipped too or just coated?
I have stage 1 cam's and valve train kits including lifters in stock as well :)
I have stock bore HD pistons which are delipped from the factory , offered in raw or coated , in stock. as well , I have machined , delipped pistons , coated or uncoated in various overbore sizes , with or without valve reliefs .
wiseguy
northern IN
yea just off top of my head on prices. I have built 3 of these in last month. If you shop around you can get good deals. stage 1 valve train kit is a plus. I personally would not waist money on ported heads for street truck. money is better spent elsewhere
