crazy wheel hop
kadeninabnitt
Martinsville, IN
on my truck in my sig every time i try and spin the tires i get a crazy wheel hop. ive tried trac bars weight in the bed changed tires even gone as far as taking the lift off the truck it is now bone stock sitting on little pizza cutter tires. it doesnt matter if im on gravel wet or dry pavement. it didnt start this till i did the 5 speed swap i could light my 44s up with no hop when it was an auto now the rear hops like crazy shakes the trans and all too. if anyone has any insight to this id like to get it fixed asap as i will be selling the truck soon thanks in advance.
kadeninabnitt
Martinsville, IN
for shaft length it came out of the donor that was a 95 ex cab lb same as mine so it should be as for swapping the auto back in wish i could but the 44s killed it and it went by by
powerSmokin
Marysville, Wa
What about the angle of the driveline? That can cause wheel hop, you prob have the right length driveline. I get wheel hop every now and then when I start to burn out on dry pavement but that's it.
obspsd
Manual Trans are prone to wheel hop in trucks, you gotta learn to push threw it lol
