Crew Cab Headliner
Agjake11
Rosenberg TX
can it be removed without taking out the back window?
going to find one from an 08 and swap it in but need to make sure i can get it in without messing it up first
Wojo
Yes u can. Remove all the seats in the truck and u can wiggle it out a rear door
Agjake11
Rosenberg TX
sounds like fun. just had to check cuz on my last truck the crew cab model had to come out of the back window
Wojo
Only reason I would want it is because it has a large flat spot at the rear that is perfect for mounting a cealing mount monitor. Im not even sure it will fit without getting 08 interior panels.
Agjake11
Rosenberg TX
I have an 08 rear window and the headliner goes down further in the back to match with the gasketless rear window. I think the c pillars work but I know there are some differences back there around the window and I don't think it would fit without changing the back window also.
