03 tx pwr stroke
I'm confused. I've been told that if I lift my truck 8" or more I have to get cross over steering and then I've been told that 8" and less I don't. So which is it?
It is a HUGE upgrade. My truck with 12" of lift with 40's and crossover steering steered 10x better than my truck on 6" of lift with 37's and no crossover.
Trust me it is worth every penny. That change in geometry is huge. I bet on a 6" lifted truck it would steer as good as stock.
My plan is to go up 8" and I want to run 38x15.50x20 or 22's.
I mostly agree with what's been said. Assuming the truck is an 03 as you have listed in your sig, you would not be able to run a crossover setup on anything lower than 8". Not 6" as layson has mentioned. Even some 8" kits have clearance concerns. That being said, a hydraulic assist kit will likely be needed in order for you to turn while stopped. A crossover kit will help slightly with that but nothing in comparison with the difference a ram assist will have. The main improvement you will notice with a crossover kit will be while driving. The '05+ trucks steering setups are different and the height at which a crossover is needed is much higher than the earlier trucks.
Yes sir, the truck is an 03. So you're saying 8" I DO need the crossover steering?
