kornfanjoe
- Joined
- Feb 4, 2013
- Messages
- 43
- Reaction score
- 0
I know it's been beat to death but I've got a few questions about an aftermarket custom fuel set up.
My goal is to delete the hfcm and fuel bowl, add a r.r. system, make it look Purdy and most importantly it CANNOT have filters that drop lower than the frame unless it can be very safely guarded. I do not want to lose any clearance underneath and don't even want the risk of breaking a filter if I go off-roading.
From my research so far a sump pick up is required then a low pressure feed pump to feed a higher pressure main pump. From there to the heads set up with a properly regulated fuel return system at the back of the heads.
I've read a lot about people going through motors on high pressure pumps without using a feed pump. Assuming this is the main cause are most of these pumps reliable in a set up like this? What's the pros and cons of the different brands. Is filtration relatively equal between brands?
