Custom tune help
Smokin 6.0
Indiana
I have a 2002 F-250. Mods in my signature. Put a HX50 non-wastegated 68mm charger on my truck with stock injectors I will be getting 300/200's in a few months. Right now the truck takes forever to spool and gets pretty hot trying. Looking for someone to write me a single tune for.mh Hydra to help it spool up until I get my Injectors. Thanks for any help !
WILD_PHIL
East TX
Subscribed. I know tuners can detune injectors, not sure about detuning a turbo.
E99 F350/zf6/guages/arp/comp/stellite/ billet wheel/ bellowed... Need more fuel and more air.
Smokin 6.0
Indiana
I just need low RPM fueling to help light it and then I guess the most fueling j can get out of stock sticks
WILD_PHIL
East TX
I was thinking the same thing. Have the fuel tapper off as the boost comes up or something.
PABowhunter
Who's tunes are you running right now? Do you know who's injectors you're going with?
I'd get with the tuner who works closest with your injector maker and start building that relationship.
79jasper
skiatook, Oklahoma
Can really detune a turbo.
For the bigger turbo, you need more fuel. Or if you could get a smaller housing to run until the bigger injectors go in.
Smokin 6.0
Indiana
There just the regular Hydra tunes you get off there website. Don't have custom tunes yet. I'm not sure who's Injectors I'm gunna go with ye t
PABowhunter
As stated already, you're gonna need more fuel to spool that turbo properly. Custom tunes should help you a little in the meantime. Exhaust housings are relatively cheap and might be a good idea for now. Do you know what's on it now?
I'd give Jonathan at Dyno Proven a call. He can set you up with everything you need.
Smokin 6.0
Indiana
PAbowhunter have you ever dyno'd your truck ? Was curious what numbers you were putting down. I considered 250/100's or 250/200's also
PABowhunter
I haven't had it on the Dyno yet. Been taking it easy for the past year with a stock trans and BTS valve body. I'm getting a full BTS this winter. It should be a 500+ hp truck though.
I've talked with Jonathan about the 200 nozzles an he really likes tuning for them. Planning on sending my injectors down to him when I do the trans and have him put some nozzles on for me.
There's quite a few old threads talking about the benefits of 200% nozzles. I'm anxious to find out first hand.
Smokin 6.0
Indiana
Yea I was thinking either 250/200's or 300/200's alot of guys say that there's really on 20-40hp difference I'm not sure
PABowhunter
200% nozzle can do everything the 100% does but quicker. This translates into quicker spooling turbo and lower egts.
Powerstroker7.3
waxhaw NC
I never had 250/200 but I went from 250/100 to 300/200 and saw a lot more then a 30 or 40 hp gain not saying that isn't true but that is my experience
