Cutting edge up pipes install
swinky
Eastern, Nc
Alright guys I've been working on the injectors and turbo all weekend but can't get the up pipes in to save my life. They're t4 divided with the piece welded to the side that bolt to where the drivers side pedestal bolts used to go it Supports the up pipes and the turbo just hangs on the up pipes. Is this how all of them are? Anybody have tips for getting them back there?
Sent from my SM-T210R using Tapatalk
swinky
Eastern, Nc
I think I'm just retarded. Do all of your up pipes have that piece of flat iron welded to the flange? The one that bolts where the drivers side pedestal bolts used to be?
I tried for 2 hours last night and couldn't get them in.
swinky
Eastern, Nc
Yeah that's still there I think. I can't get both sides of the up pipe down the back of the motor. That long flat piece keeps getting in the way. The exhaust is still on btw.
fordfreak4life
Loosen the downpipe under the pickup and lean it as far towards the heater box as you can
Sent from my SCH-R530X using Tapatalk
swinky
Eastern, Nc
Fack alright. That downpipe is clamped on there good. Thanks guys.
onebadcoastie
Elizabeth City, NC
Did you get them installed yet? I was gonna tackle mine today but I feel like dog s*@t right now. I figure the heat shield Matt mentioned would need to come off. I was just debating on whether or not the ficm needs to come out.
swinky
Eastern, Nc
My ficm is off and I still can't get it. I'm not 100 percent sure on the heat shield he's talking about. Mine aren't on man I've got the dutes today.
onebadcoastie
Elizabeth City, NC
Item #2
swinky
Eastern, Nc
That's not there. I haven't even been able to get them that far though. I was tired as hell though. Hopefully be more concentrated in the A.M
onebadcoastie
Elizabeth City, NC
So you're saying the bracket that mounts to the upper portion of the block is impeding the install?
Do you have the passenger side pipe installed at the same time?
swinky
Eastern, Nc
Exactly. I've tried with and without.
