Dacco triple disk, triple clutch steel convertor?
always-strokin
Called the high-end shop around here that rebuilt the e4od in my truck a few mos before I bought it, in an effort to get some info on my trans. I thought it was peculiar that I could tow 10k lbs, never had a slippage issue, never goes over 160-180*, and still has bright red fluid several years after I bought the truck.
Turns out it was stripped to bare case, radiator and cooler flushed, has factory valve body but has a triple disk, triple clutch, steel convertor from Dacco in Tennesee put into it.
Whats the deal w/ that convertor? Any good? Good enough for 4-500hp?
always-strokin
So according to Dacco, its p/n: hd 3696-6-2
Claims its a billet cover, and its rated to 1700ft-lbs of torque. Looks like I may NOT be upgrading my TC this summer after all.
always-strokin
3696-6-2 (110-K)
Brand: Ford
Model: FORD E4OD and 4R100
Stall: LOW STALL
Family: COMMERCIAL
Bolt Pattern: 11 1/2"
Engine: DIESEL
6 MOUNTING STUDS
Brazed Impeller: YES
Brazed Turbine: NO
Bearings: NO
Washers: 2
Diode Stator: NO
Balloon Plates: NO
Notes: DIESEL APPLICATIONS, 110-K (LOW STALL) & 95-K (EXTRA-LOW STALL) WITH 6 MOUNTING STUDS. "FORGED" COVER. MULTIPLE PLATE LOCK-UP CLUTCH SYSTEM
According to RacerX, these guys also make the TC's for Banks.
It's a "low stall" 105k unit. So probably good for towing right?
always-strokin
Soon to be a well-fueled d66. Stock turbo right this second..
Also, called Diesel Pap and spoke w/ Miss Diesel Pap from dieselbombers. Evidently they are using the same exact TC that I have in my truck. He's running 750whp in his stroke and has been doing tractor pulls w/ it since 2009.
I say I have an alright torque convertor...
kyle43335
just because dude is having great luck with his, don't expect you will have the same results...
just some food for thought.
always-strokin
Well his good luck falls inline with the 1800ft-lb capacity they are capable of according to the manufacturer.
I dont plan anywhere near 750hp or 1800ft-lbs :)
Bobby@cp
Again just because he has good luck with it dont assume you will too.... Every truck is different.
