Darn engine hoist issues
My new harbor freight cherry picker wont pull my 7.3!
Its a one ton puller, just like my old one, which picked up a junkyard 7.3. It seems physically smaller. The 3ton ram does a lot of.hissing and moaning when I crank on it.
It has pulled a 12v with an allison attached to it since I got it but it wont pick my 7tree.
Anybody ellse have this problem?
Oreilly by my work shop has a 2ton ac delco jobber for.three hundred im gonna pick up tomorrow. Gotta get this thing out!
What are you guys using? If I had.time on my side Id build a rolling frame with a chainfall/block on it. I need this.motor out though.
kyle43335
i use a 3 ton colt air over hyd. it was built in canada. as far as i can tell, theyre not in business anymore.
this hoist is a beast.
since i cant find a pic of mine. this would be its equal
http://www.etoolcart.com/enginecraneotc1814.aspx
Yea, its twisting the boom. Im not sure I wanna put an 8k lb ram on it. Its.eerily similar.to.what a floor.jack.does when its.maxed out. I realize the manual hydros only net a half inch per pump when you're picking with them. This.will level the motor out.and then it starts wheezing...:eek:
Wouldnt a heavier, beefier, 2ton be better? Especially since its twisting the boom?
kyle43335
def. i would not *** around with that.
these engines are heavy its not worth your life..
