Dash harness differences
joedown
Is there a quick way to tell the difference between a dash harness from a 95 gasser vs diesel?
Also will a dash harness from a 96 plug and play in a 95 if both are xlt models?
markfuga
Leesburg, VA
Yes, Easiest difference to spot bewteen gas and diesel dash harness is the "diesel indicator panel" which includes "wait to start, water in fuel, filter clogged, etc". Gasser dash harnesses don't have the connector for that display panel.
Yes a 96 and 95 will "mostly" plug and play. Engine operation wise they are identical. There may be some difference for options like "locks" and "windows" that may not be in one truck versus the other. Also an Fsuperduty harness will have a couple "extras" that a 250/350 won't "typically" have.
