Dash questions
Betarocker
Sea to Sky, BC
I tried the Search feature but came out with zilch.
How is the clear plastic dash cluster removed so I can put a small piece of electrical tape over the tire pressure indicator light?
How is the factory radio removed, or at least the panel which surrounds it?
2016 XLT
Jomax
Arizona
2016 XLT
LOL, find someone with IDS, they can lower the PSI for the TPMS. I have mine to set off at 25psi.
For the radio, I do not know.
ghohouston
Lewisville,Texas
Iirc, the panel around the cluster has 2 bolts up top, then with the shifter down in gear, it should pop out. Beyond that, cluster just bolts in. The radio bezel i believe has some bolts in it, then the bezel pops out, and then the radio itself is bolted in. Its been a while, but i had all this out on my bosses 15 to install an upfitter harness.
2016 XLT
why wouldn't you just find someone with a mini max installed on another truck and have them plug it in and turn the tpms light off?
Betarocker
Sea to Sky, BC
Everywhere I have looked/searched hasn't led me to believe that's an option.
Finding someone to do it might be a bit challenging as the diesel scene isn't as prevalent here as it is south of the border.
When i was in alberta, i did it myself to forcefed6.4's truck and it worked fine...
ckrueg
Belding MI
Download forscan, get an obd adapter and do it yourself. Took me 10 minutes to set the pressure to whatever you want.
