Ipkyss
- Joined
- Jul 16, 2011
- Messages
- 1,032
- Reaction score
- 0
Trying to help a friend with his truck. 08 job 2-3 100k miles bone stock. Lost an injector and drove the last few miles back to his shop. His shop mechanic put 8 rebuilt injectors into it and now it is running very bad. Shows misfire cyl 2. Blow by does not seem nearly bad enough to be a bad piston. It sounds like there is a compression leak under the driver side valve cover. Curious if maybe the injector is not seated properly? oil is a little high which I assume is from the bad injector. coolant looks good. I plan to check compression tomorrow. I will also have a snap on solus pro to use, but I have not used one and not positive what to check for. Just trying to figure out as much as possible before I start pulling things apart. I was hoping it would be a mistake from the person that swapped the injectors.
