DIY Rear blocks
Homesteader
Might be thinking of doing 6" rear blocks,does it need to be tapered or could it be flat as the stock block. Truck will have traction bars also.
Thanks
chappy
Marshall Mi
Depends on if you have a single drive shaft or 2 piece. If single then I would put a taper. If two piece then leave it flat since you have or will have the carrier bearing dropped. I plan on making a 5in one myself.
Homesteader
Isnt your truck already lifted?
Your doing 5'' rear blocks or total lift?
How taper would I need if I do need it? I was thinking just match the pitch as close to stock.
Dzchey21
wyoming
I made my own 7 inch blocks a couple years ago.
the pictures are in the sled pulling section in the sticky thread for traction blocks.
They do need to be tapered. The factory 4 inch block have about 5 degrees. I made my 7 inch about 8 degrees. I bet for a 5 inch 5 degrees would be about prefect.
If I remember right that equals about 5 inch tall in the rear and 4.5 inch in the front
fordfreak4life
Ill try to get a pic of a set of lift blocks i built that are pin located and ubolt located..... They are on a rock crawler... 4" 3 degrees of taper
Sent from my Milestone X2 using Tapatalk 2
Zmann
Below is Trevors from PMF He offers them in tapered or flat
He also makes a adjustable one for axle centering and the traction bar style also.
but He's not a sponsor so Google Precision Metal Fab if you want to see His offerings.
honestly My 4 inch tapered block was in backwards when I bought my truck
after a few months of owning I noticed so I spun them ,, never noticed a difference..
I actually just pulled them in favor of all spring .. and am working on getting the carrier and pinion angle dialed in
Zmann
honestly it can be up to the individual truck but typically the pinion needs to tilt up when lifting
so yes
there are procedures to check for proper drive shaft carrier bearing alignment and angles
He isnt a sponsor? He used to be....:shrug:
Homesteader
I have a two piece drive shaft. Will the two piece carrier bearing need to be drop compared to the single shaft?
chappy
Marshall Mi
There is no carrier bearing on a one piece so you have to correct the angle with the block taper or a wedge tied into the center bolt on the leaf spring. I'm not a fan of wedges. Since you have a 2 piece driveshaft you will need to drop the carrier bearing when lifting and that will correct the angle.
chappy
Marshall Mi
I have a 3.5 stacked with a 1 inch. Its not enough and I don't like stacking blocks so I need a 5.5in in there to make me happy.
Tom S
I was doing some reading on this and it seemed to me like it would take a combination of a wedge and a drop of the carrier to adjust for lift. I was reading that same spicer guide.
Homesteader
I looked at my 2 piece shaft and its not in a straight line. The carrier bearing part sits a little higher. When lifting a truck should the dirve shaft be in a straight line from the pinion to the transfer case? I just need to figure how much taper I would need to put into my blocks.
