Doing routine oil changes.any kind of valve lash adjustments needed on these engines?
mharring
Round mountain Nevada/south lake tahoe
Ill be doing some routine brake work and oil changes soon and was thinking to make a day of maintenance on the truck. Is there any kind valve lash adjustments needed or is hydraulically adjusted im not sure. The engine only has about 45,000 miles on it!
Engine oil recommendations?
Atf oil recommendations?
Rear diff oil, pretty sure ive got the traction lock rear end?
Is the transfer case common oil? If not what oil recommendations there?
