DPF Tank use after delete?
Sooter6.7
Eastern WA
Has anyone done anything with the dpf tank after deleting? Converted it into a fuel tank or anything? Wanting another project and haven't seen much out there. Thanks
Sooter6.7
Eastern WA
That'd be nice to see. Would there be any way to use it as a fuel tank and hook it up so when your running low you could just flip a switch and use the def tank? Seen something like that on the market for a few grand.
bigrpowr
<How I Fly
Administrator
I saw a while back where someone (maybe mike bigrpowr?) turned it into their water/meth injection tank.
no , we're working on a setup right now to make it an ice water tank for the intercooler. not too far away actually .
bigrpowr
<How I Fly
Administrator
jwalk09
VA
I believe one member on here swapped it out for an on board air system.
charles henson
This sounds like a good idea,i had thought about using it as a meth injection tank but the only review i found of one being used on.a 6.7 was less the favorable.I love this idea though:fordoval:.
WhiteMamba_Scorpion
Was literally talking the other night while working on UDPs truck about an ice box for the intercooler on my 6.7 haha. I'm a day late and a dollar short. I'd be interested in seeing how it works
UNBROKEN
If you used a bulkhead fitting on the fuel an DEF tanks down at the bottom...say 1" hose...you would effectively add 5gal capacity to the fuel tank with nothing else needed. Maybe vent the top back into the filler hose but if they were connected at the bottom the level would rise and fall with the main tank.
ftast350
When you inject water/meth into the intake in a spray it will create a cooler denser air charge, lowers the egts and creates more hp/tq
