drive pressure
mudwizer
can somebody explain drive pressure to me,and where to tap to read that pressure.thanks in advance
fordfreak4life
Exhaust manifold, drive pressure is simply the amount of exhaust pressure needed to drive the turbo.... The closer you are to 1:1 drive pressure to boost ratio the more efficient the setup
Sent from my Milestone X2 using Tapatalk 2
PSDEng
Bellefonte, PA
IF you feel really compelled to monitor drive pressure, drill a hole in the exhaust manifold and hook a boost gauge up to it. You have to run a few feet of copper tubing from the fitting on the manifold to the start of the nylon tubing that goes to the boost gauge as the heat is too much for the nylon. Chances are at some point it's going to get clogged though from the soot, and you're going to have to clean it out.
chris89
There's no way to tie into the sensor that is already in the exhaust?
