Here's some useful info to check what you have
Most likely 1350 series joints for the rear driveshaft.
1.1875 (1-3/16") diameter cups
3.625 (3-5/8") from outside to outside dimension of cups
Spicer 5-178X for greaseable or consult the chart for other options
Front, should be 1330 series
1.0625 (1-1/16") diameter cups
3.625 (3-5/8")from outside to outside dimension of cups
5-1203X consult chart for equivalent sealed joints as you might not be able to use greaseable at the double cardan.
Or for older Ford with the "Ford special 1330"
2 cups 1.0625 (1-1/16")
2 cups 1.125 (1-1/8") these fit the yoke.
Spicer 5-1204X greaseable
