08Monster
- Joined
- Sep 8, 2013
- Messages
- 1,871
- Reaction score
- 0
The speakers on my drivers side BARELY make a sound, pop sometimes. Ideas?
Yep. Sounds like it may be a great time to upgradeIt was just the front passenger speaker for me, sounds like you may have something else going on?
Keith
That's for all the leads, it works now..... LolEasy to diagnose, may not be so easy to fix. Problem areas: door boot between door and cab where the wire bundle is, check for any damage. It sounds to me like a ground, most likely an exposed wire. Next check the connections to the speaker themselves, often the connectors work loose or get condensation. If it is water and you know it could happen again, get dialectic grease and coat all your speaker connectors. If it's none of those, then bust out a multi meter and check resistance on your connectors, any that are MUCH higher than the others will tell you if it is an exposed wire.
