Driveshaft Questions and Part #'s
bri_grogs
I started to round the bolts that hold the driveshaft into the t-case when I removed them. I know these bolts have the funky 12 point head, but the threads look like regular coarse thread; is there a special part # or can I use a grade 8 bolt with identical thread?
The female end of the driveshaft clearly has a spline that is wider then the rest, but the male end of the shaft looks to be identical all the way around. Did I overlook the corresponding wider spline? If not how do I ensure I put the halves together correctly?
08Monster
Grade 8 with same thread size and pitch will be fine. 12 point just take more torque with a smaller head. Meaning you can have a smaller head on a bigger shank without worrying about rounding it to torque or remove it. I'd get the same ones if it were me though.
bri_grogs
Id love to get the same ones but my google search didnt turn up a part number. Any idea if I can get these at the counter from ford?
JD3020
Farmersville/Dayton, Oh
Just take one out and go to any local hardware/fastener store, they will be able to help you out. I'm sure Ford could order the bolts, but they'll probably $10+ a piece.
08Monster
Ford will have them. If not, get a comparable, 12 point, grade 8 or higher washer head bolt.
