Milford
Ok this truck has a p0275 for a balance fault on number 5 cylinder. Took the injector out and swapped with #3 which is good and still same thing. #5 balance fault. The harness ohms out fine and within .1 ohm for each injector from the valve cover gaskets main harness. I am going to check the main harness on the truck today and see what that brings but does anybody else have some suggestions? I checked blow by the simple way with the oil fill cap and its pretty minimal especially for what this truck is. That's the only code in getting on this thing. Any help would be great!
