Edge cts boost question.
ODAWG714
Orange*County, CA
I recently removed my analog gauges and installed the cts. Now my boost reading are lower. My question, if I re route the boost line from the map to the intake elbow would that give me a more accurate reading? And would it trigger a cel if done?
HOOV3R
Central PA
You could add on the 0-100 psi sensor to your cts. I'll compare my two readings in a little bit when i drive to work.
HOOV3R
Central PA
Comparing factory sensor to add on.
0-10 psi - factory is 1-2psi low
10-29psi - factory is 2-4psi low
29+psi - factory will not read past 29psi, but add on continued to 35psi
Tried to get a video, but it didn't turn out so well.
I believe its the map sensor itself that skews readings, not the location.
