Edge Insight cts update
BIG JUICE
Valrico FLA
Hey guys, did the update edge emailed me about for insight cts monitor.rail Fuel pressure, exhaust back pressure and injector timing are supposed to be able to be monitored after the update, there is no such option under the PID screen. Am I missing something obvious?
borsky
Barrhead AB, CA
I had the same issue I emailed tech support they asked for my SN, then emailed me back and said to try again and it worked
The update is ONLY for the CTS2, correct. They will not be updating the CTS if I understand correctly. Makes sense from a manufacturer standpoint. Don't update the older units so it forces everyone to get the CTS2. I can't fault them for that I guess.
O4ep3civ
So some people had to call and give them your S/N and some didn't for the original cts?
HeavyAssault
Middle, VA
That's BS. WTF Edge sends it if you ask for it but doesn't make it part of the update push. More BS>.....UGH.
borsky
Barrhead AB, CA
I think it was because I had just tried to update it a week before the new PIDs for the 15's came out, when I plugged it in. The CTS thought it was already updated. Don't forget the majority of users aren't running this specific truck so wouldn't care if a few PIDs for 15 6.7L weren't in the update. Yes it works on cts #1, if your running on and haven't updated for a while, I'd suggest trying it and I bet you'll have them after an update...
BIG JUICE
Valrico FLA
E-mailed edge, they said update it now. I think they needed to put my serial number into get it to have the latest
