EGR DELETE HELP
Sooter6.7
Eastern WA
Hey everyone new here to the forum, power stroke org and the H&s forums were not doing much good so here I am. I am full deleting my 2011 f250 6.7 using No limit EGR delete kit and I have the egr almost off but there is a 10mm nut that they say to take off on the back side of the egr... There's no way I can get back in there!! I took the Plastic intake off and tried to get in there but no way. Even tried to get it from under the truck but am in a hole. Any suggestions or help would be great.
UNBROKEN
A combination of 1/4" extensions and u-joints and you can reach everything needed for removal.
Sooter6.7
Eastern WA
Okay so that is under the truck looking up
Sooter6.7
Eastern WA
I don't think that will do much good because even with that off the top of the engine bay and plastic intake box block me
CWAY6.7
That intake box is 2 bolts and it pops out very easily. Also the battery on that side is easily removable.
UNBROKEN
I didn't take anything extra off. Just unbolted the cooler from the top, lifted it off and slid it out.
Sooter6.7
Eastern WA
Okay guys so I've screw that 10mm but out that far and I still can't get it out!! What else can it be?
Sooter6.7
Eastern WA
Finally!!!! Now how did you guys set up your EGTS to monitor everything? Factory? I have the H&s pyrometer I will install today but what about the factory one?
CWAY6.7
I think you use that harness for retaining the stock EGT sensor with blockoff plates. Since you have the H&S pyrometer though, you just get rid of that one/unplug it
