egr delete question about antifreeze draining
Ctsvnino
North jersey
do you really have to drain the antifreeze from the block to do the delete? on my other diesels i had i dint have to. i know there pressure but how much do you loose?
Raptorgabe
I just cut the stock radiator hose right before the mesh and put a coupler in there and hosed clamped it together
Raptorgabe
Prolly cu the hose is a pos to get to and to cover their ass if antifreeE gets in any open holes
HeavyAssault
Middle, VA
Both radiators have a pretty small drain port. I think we used a 19MM socket since the damn thing is f-n tight. Get under the truck, find the outer corners and you will see the drain port. It will take A LONG time to get 5 gallons out.
UNBROKEN
That's no sh!t. Took forever so I gave up. It was faster to go buy 2 gallons to throw back in. LOL
Powerstroked162
On Da Juice
Wa. State
Split the main system hose at the crossmember, under the front of the truck in front of the axle. It's got a quick connect retainer clip. Simple, and you'll have the primary side empty in less than 30 seconds. 11-14 trucks need to drain the secondary radiator system since it's tied to the cooler as well. I found the fastest way to do that was to remove the secondary coolant line at the base of the radiator and catch what you can in a bucket.
