EGR delete up pipe issue
powerlifter405
Butt Town
Last weekend I wasted the whole weekend trying to install a delete pipe.
I purchased the whole kit and 2 things stuck out.
#1 The coolant hose was too big. It fit really loose and before I could even get it a chance to leak I got a smaller hose.
#2 The up-pipe s$cked @ss.
I spent 2 days trying to get the exhaust leaks to stop. Both manifold flanges were leaking and even the marmon flange/turbine inlet leaked. There was exhaust smoke filling the engine compartment and the truck was 100% not drivable.
Fast forward to last weekend.
I took the factory up-pipe and welded the egr hole shut. I then welded the up-pipes together for simplicity. I dropped it in and w/o any fuss everything bolted up perfect 100% no problems, no leaks.
I measured the two side by side and there was almost a 1/2" difference between the factory pipe and the delete pipe. Now I know why I couldn't get sh$t to line up the first umpteen times.
I'm waiting to hear back from the seller. Also this had me thinking. Guys have complained about blown bellows. I wonder how many of those were deleted units?? I say that because if someone was lucky enough to get things to line up by some miracle, the bellows will be stretched out enough that I could see them wearing out faster.
Anyway, maybe this will help someone and it's a cheap way to do it.
Get the coolant delete tube then weld your up-pipe and viola. Your deleted for less than $50 bucks and your back to 3 bellows. If someone really wanted to they could buy some new one's cut the old ones out and redo all their bellows for under 120 bucks.
HeavyAssault
Middle, VA
That's basically the "sneaky pipe" mod. That was used to keep the "look" yet run a bypass on the EGR cooler.
When I was running deleted I did have the OEM bellows separate on me. Getting a custom Y pipe with HD bellows was the solution.
powerlifter405
Butt Town
I took the cooler out but kept it should I sell the truck to someone who needs the cooler installed. There was a night and day difference between ease of install and considering the seller involved I was very surprised. In the end the sneaky cheapy mod works well.
These factory units have 289k on them and their g2g so far. If/when they go I'll cut the old out and weld in new. I plan on staying close to stock for $$ and reliability so I'm hoping I can squeeze more life out of them.
powerlifter405
Butt Town
The seller refunded some $ so I'll give away the delete pipe if anyone wants it, cost for ship only.
I'll get a rough price but prolly 10 bucks or so.
