Electric fuel?
tonto13
I have read the threads on the fuel systems. My question is I have only found 2 kits the still use the tank selector valve. That is something that I really need to have, I also have a 90 gallon tank in the bed that runs straight to the motor. This was already on the truck when I bought it. What is the differences in the kits that still use the tank selector switch versus those that don't?
FrankTheTank
Cecil County, MD
Where it ties into the fuel lines at, also most kits were meant to support larger injectors which cannot be supported they a single factory selector valve.
If u will never go over a stage 2 (160/100 or around there) then u will be just fine going thru the factory valve and a basic e-fuel kit
tonto13
I have the Swamps Baby injectors and Swamps chip. Mine is a daily driver and moderate tow truck.
FrankTheTank
Cecil County, MD
U will be fine pulling thru the selector valve, u can get any kit, just tie it into the stock lines after the valve with proper size hose
