ok so i have a bunch of issues going on. a little history for you guys. im new to the forum but ive been around the block a time or two.
the history goes like this. i converted a f350 460 cclb 1994 truck in to a powerstroke. i had a high mileage roached out truck of the same year with a powerstroke in it. swapped over everything, underdash wiring, chassis harness fuel lines exhaust system core support and the list goes on.
the issues i am having are all electrical related. my original dash harnes had been spliced and hacked into a bunch. i dont have working brake lights. hit the brake pedal and blows fuse in panel. direct short to ground. cruise control didnt work and the powerwindows would work for awhile and then pop the fuse.
so i sourced a 1997 underdash harness that came out of an automatic truck. i just installed the harness and now i am having more problems. this new harness is in way better shape. it surprised me that it didnt work. so the issues i am having now are:
wipers wont work, cb in fuse panel is hot. ohmed circuit to ground and i have a short.
TPS wont work- found out that the wiring in the 1997 harness is a little different. i think i have the wires figured out to get the signal voltage back to pcm.
now the headlights arent coming on. the running lights light up but the headlights dont work. i need to confirm that bulbs arent roached but they worked with the stock harness.
and the brake lights still pop the fuse as soon as the pedal is pushed.
truck specs. 1994 f350 4x4 cclb gasser converted to powerstroke. i put in a 1996 444e motor. zf5 trans. 1994.5 computer and idm. 1997 dash harness out of an automatic truck.
any thoughts or ideas are greatly appreciated. im beeting my head against the wall trying to get my truck on the road. if any one has had the same issues or has any clue please do chime in.
thanks for the time guys.
mike
mike
