Elite diesel Dual K16 Fueler kit
Dzchey21
wyoming
Im selling my dual fueler kit off the old race truck.
Elites kit that comes with pulleys, used pump to mount up front, belt, lines, fuel bowl delete with fuel lines and fittings.
Everything is in good shape, the pullys have normal wear from the belt but nothing major. Nothing wrong with any of it. Truck made 950 with them right before i tore it apart
Will maintain 27,000 psi @ 2.2 pw with either Elite 200s or MPD 100% over nozzles
on elite site with a new pump its 3700
Asking 2500 for a couple reasons, you might have to get some additional hardware, my engine doesnt have the studs for the front accessories so I had to use some other hardware. Pretty minor in my book
Comes with
2 pulleys, one is already on the pump
K16 pump, good used pump works fine low miles under 6000 miles
Fuel lines
Fuel block for the high pressure lines
Fittings to go in the back pump for fuel supply and the dual fueler line
Fuel bowl delete (missing one spacer because i had something else in one of the holes
Fuel bowl delete comes with lines to run to both pumps and to run to your fuel system, you might need to make it longer for a crew cab ect
Wire harness for the pump controls
2 idler pulles
1 Belt tensioner
1 BRACKET for the K16 already bolted to the pump
1 Belt
You will need to trim your fan shroud or i can send you mine and you send yours back after install
you will need to trim the pass battery tray (not sure how much i didnt have one on that side)
Ill get some pictures later but its pretty straight forward, If you have questions please download instructions before buying so you can be sure you can do the install.
Dzchey21
wyoming
Make me an offer, i was just throwing a price out there not sure what they are really worth
Dzchey21
wyoming
Still have this
Couple things I need to add is this was ran without a regulator on the fuel block. I ran an ad 150 so it was always set to 10psi. If you have a low pressure system you will need to come up with a way to regulate that pressure down to 10 psi or so.
I did find the fittings to run return fuel line to the fuel cooler. You may need a longer hose tho I'm not sure. I'm sending the kit out with lines cleaned out and capped as well as cleaning the inaide of the pump. If you have any other questions let me know. Price is still 2500 thanks
Dzchey21
wyoming
kit is still for sale, this time without a pump. Got damaged during shipping to someone else. Everything else is fine. From what i have been seeing most people want to put on a new pump anyway so ill lower the price accordingly. 1750 obo
