Elite Dual HPOP
HOSS-06
Ontario, Canada
Hey guys,
Picked this up off a fellow member on here a couple months ago along with some other parts.
I am using everything else but have decided I do not want to run the Dual HPOP.
The kit is complete with pump, brackets, sensor, belt, hoses, and new passenger side valve cover. Pump has one hours of idling on it.
attachment.php
2500 OBO
ncdzl
Always wondered...where does the secondary pump tie into the stock hpo system?
HOSS-06
Ontario, Canada
The Elite system ties into the factory system 3 places.
First goes into the factory HPOP itself, this acts as a balancing supply and then the other 2 run directly into each HPO rail so you are not relying on all the extra oil running through the factory oil supply lines. The ICP sensor comes out of the passenger side valve cover and you feed oil there. the ICP sensor is relocated to the Elite supply block.
Pizza pig
MD
The elite kit is something like a HPODS system from diesel site with another pump in the system. Other kits take oil from a source like the oil pan and feed the test port on the pump for the newer rails, and some feed directly into the log style rails of the older delivery system
6.0Powerjoke
Connect I Cut
Will this kit work on the old '03 style systems>???
HOSS-06
Ontario, Canada
Hey everyone this is still available was going to open a new thread but Ill try and save this one first. New price..
You'd get Elite dual hpop includes,
pump , billet aluminum EDE pump bracket, HP pump pulley, Billet aluminium oil filter cap, passanger side valve cover with NPT bungs welded in, ICP sensor, Belt, misc fittings, hydralic hoses. Think thats everything
$1950 shipped. .
