Elites HO vs RCD 68
EShore,MD
Ive been looking into getting a 68 vgt recently. Im running a batmo powermax now with 190/100s and it does well but im still hungry for more... So i would like to hear peoples opinions on what they have experienced with 190s and the 68s
Redneck6.0L
Don't quate me on this but I think elite puts a larger exhaust wheel in there ho where rcd only mods the intake side. If you don't care about towing. I'd go HO. They've proven to make the best HP of any vgt so far. Still doesn't mean I like vgts LOL
windrunner408
Would the HO produce less back pressure than the 68mm PM because of the larger turbine wheel?? Or would it not make any difference??
faster6.0
Larger turbine wheel makes all the difference in the world. More free flowing exhaust means more potential power/less back pressure.
kyle43335
fyi,just for refrence the 64/71.70 t3 open we bought from younger went on a f-550 with my old 205 50%.
that charger runs a perfect 1:1 at wot. tuned for full tilt.
strokin6L
Springville NY
My current 64/71/70 T3 open non vgt will hold 1:1 all the way to around 40psi then back pressure starts to rise a bit over the boost. When i dyno'd...boost was about 45psi and BP was around 53-54psi with 190/75's.
windrunner408
Well VGT turbos will probably not ever be able to be ran at anything close to 1:1 at WOT. What is the general consensus on how much pressure (boost or back pressure) our engines can take when studded before the gaskets will give out.
BlueWaffle
Grapevine, TX
assuming the turbine side stays the same as the pmax on the 68...its 72.5/66.5 inducer/exducer. HO is 72.5/70. I'm still trying to find out the specs on both the compressor and turbine side of the 68. on the RCD website, it says the 68 has an enlarged turbine side as well so I'm trying to clarify that.
and bp will always be higher with a VGT will it not (i.e. not close to 1:1) ??
kyle43335
correct.
the whole point to the vgt,is that even at low rpm,the veins are closed creating a dam effect to bump the pressure.
then at higher rpms the veins are now open to allow flow(engine has much better exhaust pulse),problem is now the veins become a restriction.
i have datalogged bone stock trucks ratios,and this is what ive seen...
the charger upon building boost will rise around 2:1 ratio under moderate to heavy throttle, once max boost is achieved the ratio comes in around 1.25-1.50:1
keep in mind bone stock truck
once you tune the same platform,those numbers go up...
hope this helps
BlueWaffle
Grapevine, TX
correct.
hope this helps
right...i think people will get scared off with high BP #'s because they hear all about 1:1 stuff with non vgt but that's the nature of the VGT. I am curious what the limit is to keep hg's in place though
kyle43335
that mysterious number? lol
just for the record my blue truck has seen close to a year of non vgt duty,with drive pressures in check.
countless wot 30-35 psi runs.(stock injectors) it pulls harder than any vgt hot tuned stock truck ive driven,it also runs cooler than with a vgt.
this is all on a 154,000 mile engine.stock head bolts and gaskets engine.
makes you think doesnt it?
BlueWaffle
Grapevine, TX
are you comparing a stock vgt and aftermarket non vgt? if so....of course it's going to pull harder and run cooler than the vgt.
either way...there's no arguing that bp is going to be much more manageable with a non vgt. :thumbsup:
anyways....back on topic.
EShore,MD
Yeah I tow a boat once a weekend in the summer that's5k but that's about it . Im liking the fact that elites will have less bp because of the enlarged turbine. Now does the ho have a cast or billet compressor wheel ?
kyle43335
im comparing vgt to non vgt. they bolth have their own pro v cons.
Lubbockguy1979
Lubbock tx
What kind of hp gains are you going to see from a pm with batmo wheel vs. Rcd68pm vs. The ho?... It would suck to drop some coin for small gains in my opinion
BlueWaffle
Grapevine, TX
I'd think HO and RCD will be in the same neighborhood. I'll have track times and maybe a dyno pull this weekend in ennis to see what gains the 68 has over the pmax. sure feels stronger!
