mooring product
The quest to eliminate sway is still a battle for this overloaded truck with a beer budget.
After reading about all the fantastic aftermarket sway bars that I couldn't afford I saw someone post about upgrading the bushings in the rear sway bar. So I ordered the rear kit for my truck that has the 30MM bar.Not sure why I didn't think of this because a couple years ago I swapped the front sway bar and track bar with Energy Suspension kits.
The install was easy until I got to the drivers side where the sway bar bolt was located between the frame rail and the gas tank..after an hour with a 4" cutting wheel, a small torch and small blood lose I won the battle. (Dumb design Ford!)
Here are some pictures showing the final install. Included are pics of the front sway.
One tip is to do one side at a time so that the swat bar doesn't fall forward and break the ABS sensor on the differential.
Ford F250 Energy suspension 30mm Rear sway bar by MooringProduct, on Flickr
Ford F250 Energy suspension front swaybar by MooringProduct, on Flickr
The reason for the sway.
Untitled by MooringProduct, on Flickr
