Engine build
Spindrift
Austin, TX
Unfortunately, my preliminary diagnosis of what I thought was a failed flex plate turned out to be the beginning of an engine failure. I still haven't recovered from the news so if I don't make total sense in this post cut me some slack. And yes, funds are limited. I need to quickly put together a budget for our family's CFO...:priest:
I don't want to believe that the current set-up; 22.5 wheels, 4.88 rears with a Truetrac rear and 175/75 injectors towing a 16K fifth wheel had anything to do with the failure.
So how do I start this project? Given work and family schedule and the fact that this truck is our second vehicle, I'm not inclined to think that I can pull this off by myself. I need to get back on the road A.S.A.P.
I suspect a short block is the way to go...
webb06
Seneca, MO
Short block or long block would be the fastest. I'm not sure if ford offers a short block anymore or not. But most aftermarket companies like elite and rudys probably don't have them sitting on the shelf unfortunately so you're limited on availability there. I just did a complete engine build on my 6.4 and I was down right at a month. I did all the work myself besides machining.
Spindrift
Austin, TX
Ford dealer quoted a short block this morning at $4500. Crazy.
In another thread about my flex plate I talked about the knocking sound. At this point I'll assume, once again :poke:, that a rod bearing has crapped the bed. If that's the case, I can do just a bottom end build and keep everything else intact. Don't need to take the top end apart and I wouldn't need a new block.
4.0l sahara
shelton,ct
Find a good used engine and go threw the top end. Pm airfish on here he is in DE and sells lots of good long blocks.
F-250-Owner
Masontown Pa/Maputo Mozambique
I just got a very nice jasper remanned engine in.... its out of a f650 so the best deal would be a short block setup that you would need to add your front and rear cover to, I have an oil pan here for it pm me if youre intersted...
Sent from my GT-P5113 using Tapatalk 2
kyle43335
there isn't anything good with a jasper name on it. i would buy a engine from jj first!!!
jasper = junk
F-250-Owner
jasper = junk
To each their own.....I have never had any issues with the ones I get in here.... worst thing ever was finding a new valve guide after ups rolled it down some stairs while delivering it.
kyle43335
i have seen, heard many horror stories involving jasper. the company is a joke period!!!!
i had a jasper rep come in my shop trying to get me to pimp they're remans. i politely threw him out of my shop.
you should have seen the look on his face!!! priceless.
HOOV3R
Central PA
Local guy to me is selling an 03 that ran when it was removed for $1200, it's in central pa. Engine hasn't ran in 3ish years though. Might be able to get him down in price.
