Engine shut off while raining
njjeep
Brick, NJ
I was driving home from work in the pouring and my truck shut off stoping at a light. H&s no longer works it just turns on, also the dash shows a blinking car with a lock. The gear indicator does not show what gear your in anymore. It will not even crank.
2008 f-250 job3 77k miles h.&s. And egr delete
njjeep
Brick, NJ
I also hear a solenoid clicking under the passenger side dash when I try to start it
Dzchey21
wyoming
check battery voltage first off, almost sounds like the alternator quit and now the batteries are completely dead
Check both batterys power and ground cables on the battery, on the drivers side there is a screw on terminal that powers basically everything in the cab, check that for sure.
njjeep
Brick, NJ
12.5 volts in the batteries. Battery connections are tight and clean the ground on the passenger side engine block is tight.
Any fuses I should check?
WoodBoy
Alabama
Dang this has been happening a lot lately with 6.4s. Did you try and jump the starter at the passenger battery?
njjeep
Brick, NJ
Touched the small wire on the starter and it may have sparked
lazlow
Check all the grounds on the frame/cab. Bad grounds will make all sorts of crazy things happen
dzldoctor
Have seen some rubbed through wires where the harness follows the bottom of the radiator support. For the same exact issue. Always when wet.
WoodBoy
Alabama
Your PCM and all is in protection mode right now. You have a short or something you got to find first.
drunk on diesel
check the big connectors in the driver's wheel well... they're a bia to reach from the top, they're a bia to reach through the wheel well, but you might try disconnecting/cleaning/drying/reseating them. worth a shot. also check for rubbing/chaffing right there on those two big harnesses
njjeep
Brick, NJ
Ok going to pull the inner fender liner on the driver side and check everything
njjeep
Brick, NJ
Chafed and cut through wires.
Never thought I would be happy to see something like this. Now to figure out how to get them connected again lol.
njjeep
Brick, NJ
Just spliced in a small wire real quick on the broken one started right up
